My New filters arrived today, photos below, paid $109NZD from AliExpress. Came well packaged and fits perfectly on the drone. Shot the below Waterfall TimeLapse with the ND1000, let me know your thoughts. Unedited footage, just added music.
Yeah, I noticed that as well and thought it was because of the clouds above. This was shot from 103 meters high and at 3X zoom lensThe waterfall kept shifting color between white and blue, every once a while. Not sure if it's a metering problem, or some sort of color cast from ND filter?
Probably just Auto White Balance jumping around, or did you set a manual WB, which remained constant during the changing white balance during the hyperlapse duration?Yeah, I noticed that as well and thought it was because of the clouds above. This was shot from 103 meters high and at 3X zoom lens
White balance was auto because I had iso and shutter manually set.Probably just Auto White Balance jumping around, or did you set a manual WB, which remained constant during the changing white balance during the hyperlapse duration?
I will try playing around more in proper sunlight, hopefully its not the filtersIf not the cloud's fault. If you look closer, at 0:20s, for a brief moment the video became blurry and lost focus. That's the moment the entire scene turned from "blue and green" to "black and white".
Hey Mate. I will really like to try them properly when the weather gets better, more sun. Crappy today with all those rain clouds going byHey fellow NZ’er! haha I’ve LITERALLY just brought those as well on AliExpress just now ! So was looking for reviews lol
I’ll get the Polarpro when they are available but will see how these cheapies do…
Haha yup !! Same up here ://Hey Mate. I will really like to try them properly when the weather gets better, more sun. Crappy today with all those rain clouds going by
Not sure how the white balance being in auto relates to fixed ISO and shutter. It's not part of the exposure triangle. However, auto WB can definitely cause color shifts, which which is why most professionals will set a fixed manual WB, which is easier to correct in groups of images.White balance was auto because I had iso and shutter manually set.
Thanks, I will give that a try on the next shoot test. What value do you recommend for WB?Not sure how the white balance being in auto relates to fixed ISO and shutter. It's not part of the exposure triangle. However, auto WB can definitely cause color shifts, which which is why most professionals will set a fixed manual WB, which is easier to correct in groups of images.
sweet, thanks will give that a go.A good starting point is around 5500 /6000
Or another way is to put it into auto white balance and then click manual (it’ll get the correct WB then will lock it there
If you are shooting DNG, it really doesn't matter because you can easily change it in editing. If shooting JPG, it needs to be pretty accurate because WB is pretty baked in a JPG, so, as suggested above, set it to Auto, make sure it looks right to you, and then lock that color temperature to manual.Thanks, I will give that a try on the next shoot test. What value do you recommend for WB?
That seems to be the case case with everything Mavic 3 Pro related, including the drone availability! DJI is also playing catch up! This one is an immediate hit!I preordered PolarPro. Unfortunately they won't be available until the end of June...
It’s CV definitely what the M3 SHOULD have been! Even just having faster GPS acquisition is greatTh
Personally, I think a single frame still shot properly edited would have been better. I am figuring that for a 25 second video, at 24 frames a second, x 25 seconds, = 600 frames. I divided this by 60 and got 10 minutes, which is the time the one needed to be in the air at an interval of 3 seconds. What was your exposure setting? Here is a single edit using the masking tool and the falls as the subject. I could not bring out any details in the water.The waterfall kept shifting color between white and blue, every once a while. Not sure if it's a metering problem, or some sort of color cast from ND filter?
