What case for Mavic Pro w/Goggles?
GoBigGuy
Hi All,
I just ordered the DJI Goggles and now looking for a case to carry the Mavic Pro fly more combo with the goggles. Below are a few I found that didn't cost an arm & leg that look like they will fit everything. Let me know if you have tried any of them or have one you recommend?
https://www.amazon.com/dp/B074V7DYH...olid=3AA12MI8PLRWZ&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B075815VR...olid=3AA12MI8PLRWZ&psc=0&ref_=lv_ov_lig_dp_it
https://www.amazon.com/Goggles-Imme...pID=51lkrtL3jdL&preST=_SY300_QL70_&dpSrc=srch
I don't have one of those listed, since I already had a nice compact case for my MP, and wanted only a case for the goggles (only take them with me to fly maybe 50% of the time).
This is the case I use for just the goggles (well, plus cords and lenses):
https://www.amazon.com/gp/product/B07311BV3Y
One thing I don't like is that the Googles can (and have) turn on by themselves in the case I bought. Looks like at least one of the ones you listed could might do the same thing (that side button is easy to press).
Mike
I'm thinking of getting the all in one case so I can just switch back and forth from the mini case and the full case.
Can you tell me how hard it is to remove the headband from the goggles? Some cases have you keep it on and others have you remove it so wondering if that will be a pain to do.
Mike
There is a surprising amount of force needed to remove mine, but not too bad. This despite there being a button to press in order to remove headband. I have started to remove my band, but only enough to disconnect battery, while in the case to prevent it from inadvertently being switching on.
Mike
Hi All,
After I got the Goggles, I got this case to make the entire set up portable, love it:
https://www.amazon.com/gp/product/B0749MLBHB
I was just working on trying to fit everything in a small case that i got with my goggles.
I've already dealt with the large cases with the phantoms and still want the mavic to be portable.
I removed the foam and was able to keep the headband attached and put batteries, mavic, and controller inside.
I have the soft bags to put everything in seperately and keep it fairly secure.
it's not for traveling on a plane or anything rigorous but small enough for day use and I'm gentle with my stuff
danyjames_
