5P has that crazy Air 3S RTH under trees, through buildings
Droning on and on...
Santa Cruz, CA
Wasn't obvious to me, but it worked when I tested it. Yes, the Mini 5P will follow a complex path during RTH that goes under tree canopies, through underground parking lots, all without GPS, just like the Air 3S. Did a simple test yesterday, took off from a table outside in a covered area, and it followed the outbound path in reverse during RTH and landed right back on the table!!
Watch:
I agree, and won't be using it. I wanted to see if it was there, and was quite impressed seeing it work.
It does show how much computing power is going in to these mini drones now. It must be using the LiDAR to map its surroundings as the drone is piloted out into open space then using that map to guide itself back to the takeoff point through the obstacles and land under RTH. I notice the drone rotates orientation to match takeoff heading just like the Mavic Pro did in 2016/7.
velsbit
