FAA sUAS 400’ AGL Requirement
BBOjai
Ojai, California, USA
Just wondering why DJI can’t find a way to show me, at least “in general”, what the AGL altitude of my drone is. Seems like it shouldn’t be all that difficult. Knowing the altitude at my takeoff point doesn’t help at all for me to stay within the 400’ AGL limit.
Reactions: Drgnfli and Lbesing
Accurate AGL measurement is done with a transmitter and receiver that measure distance using Doppler radar and as Meta4 said above, that system is cost and weight prohibitive for the type of drones we use as hobbyists.
A Radar Altimeter works by bouncing a radar signal off the ground and measuring how long the signal took to return. The software knows how fast radar waves travel (the speed of light), and how long it took, so it halves the total distance to get the altitude above the ground.
It is really as tleedom mentioned, what sensors would you have DJI use to detect altitude hundreds of feet in the air? LIDAR? Your need to shell out some money for the DJI Matrice 200 or 600 to get that.
Reactions: M2Pro
I don't think it's a matter of they "Can't" but a matter of:
  • Is it practical?
  • Will you still buy the aircraft if it now costs $5k instead of $1500?
  • Are you willing to sacrifice flight time, flight performance and other "features" in order to fly around with this new heavy & bulky equipment?
I'd say most likely the answer would be NO in all cases noted above . . .
The fact that we are limited to LOS operations, estimating the altitude of your AC within your flight range based on your launch point should not be a problem. A simple map reconnaissance should provide you with a good start.
If you pre-plan Litchi missions, you can use the option to utilize a Digital Elevation Map to create a mission in reference to the AGL at the various points of your mission.
You can get laser range finders
Here are some options (with prices) : Radar Altimeters - Radar Altimeters from Freeflight Systems.
If you strap a 3+ lb radar altimeter on the Mavic you won't be needing an altimeter.
Oh come on all you need is one of these with the optics stripped out. Your looking at altimeters for manned aircraft. Sure I won’t want to rely on one of these for IFR manned aircraft navigation but it should give you plenty of accuracy for our purposes.
Then teach a squirrel how to use it then send back the distance using hand signals.
It was asked what type of sensor would be light enough and cost effective
Maybe this: SF11/C (120 m)
It's relatively easy to make it work with equipment such as Pixhawk flight controllers.
If your DJI equipment (Matrice 210 or M600) is capable of interfacing PWM or IC2 signals, you are good to go.
I think I kinda understand what you all are saying.
It’s just seems that if I can get relatively accurate altitude readings from my iPhone & a map app while hiking, it wouldn’t be that difficult to install software for the drone to relay altitude at AGL. I do admit I’m very technologically challenged :) !!!
You're right. It should be no problem for DJI to let operators download DEM for the area they intend to fly.
But be aware - is the DEM accuracy enough for your intended flight?
What accuracy does the DEM provider guarantee?
In addition, there might be buildings, antennas, trees and whatsoever you have to take into account.
Where does the DEM come from? Whoever supplies it most likely is charging the user(s) ...
Yes there are several small laser rangefinders that are activated remotely. ATN makes a laser rangefinder that attaches to your firearm and is paired via Bluetooth to their Smart scopes and activated by a remote button used by the shooter.
The problem with a laser based rangefinder is that the beam is very small and any gaps in the surface you are over will result in fluctuations in altitude readout. A wooded area would be a good example. Not to mention the errors caused by variations in reflectivity (Sp) of the surface measured.
Reactions: BigAl07
I just thought of something that, in my simple mind, should be easy: an overlay map or just the DJI map showing elevation contour lines. I just can’t see how that would be very difficult. Oh well, I’ll just continue guessing the best I can when flying up or down mountains.
With Litchi you can set the map to google terrain to see the contour lines
KarstenG
