- Joined
- Nov 22, 2017
- Messages
- 305
- Reactions
- 42
- Age
- 48
If you must fly in the rain, like for search and rescue maybe, you might want to look into Mavic 2 Wet suits. It’ll keep your drone dry in the worst of weather. I think they cost about $79 USD.
There was a post on a Mavic Pilots a while back as well.
All VLOS stuff aside yes. Still, Part 107 states that remote pilots must keep their UAVs at least 2,000 feet from the side of a cloud and at least 500 feet below a cloud. This is to provide extra space for traditional manned aircraft that may be coming in and out of the clouds.All VLOS stuff aside ... It's not good for the electronics - and remember that there is a fan to pull air in from outside across the electronics to keep them cool ... If that air is a shower - it's not going to be good.
Another thing that's been reported, is problems getting the Mavic to descend through cloud ... it appears to upset the downward sensor pack and the Mavic just creeps down so slowly, that I've read a tale here about someone who thought their battery would run out before the Mavic came down!
Yes, manned aircraft fly thru clouds all the time. Depending on the pilot's intestinal fortitude, IMC can be a hair-raising ordeal in and of itself. Don't further complicate their (or their passenger's) day by putting a solid object in a cloud they could potentially ingest into a turbine, rotor, propeller, etc.All VLOS stuff aside yes. Still, Part 107 states that remote pilots must keep their UAVs at least 2,000 feet from the side of a cloud and at least 500 feet below a cloud. This is to provide extra space for traditional manned aircraft that may be coming in and out of the clouds.
As an instrument rated pilot, intestinal fortitude has nothing to do with this. If I am flying IFR and being controlled by ATC I may be flying in the clouds and not by choice or guts. VFR flights are required to stay out of and away from clouds, as well. Part 64 and 91. Safety is the reason for rules.Yes, manned aircraft fly thru clouds all the time. Depending on the pilot's intestinal fortitude, IMC can be a hair-raising ordeal in and of itself. Don't further complicate their (or their passenger's) day by putting a solid object in a cloud they could potentially ingest into a turbine, rotor, propeller, etc.
if you want to fly in mountains in the mist/clouds - i would second getting the phanthomrain`s stickers as they will help to protect the battery. it works, to some degree, but, remember that drone is still not a submarine and any moisture sucked in via vents will go on the circuit board and will need to be dried out. will it or will it not short - most likely not, as board is reasonably hot - 70 or so deg - so it should be evaporating and getting pushed out by the fan, unless you will fly it under a waterfall or into similar non-acceptable place with way too much water in the air.Is there a trick to do it safely or it will damage/destroy the drone?
You need to have atti mode configured for that instead on either T or S.I had an issue where my M2P flew upwards 100ft on its own because of dense fog down low. The downward sensors caused it to fly up on its own.
After I disabled them the drone hovered fine but the GPS was all screwed up. Just brought it home and called it a day.
