Greetings from the. Northcoast of Humboldt County, CA
marcopollo
McKinleyville, CA
Greetings! New drone pilot with new DJI Air 3 from Humboldt County, CA. Excited to get flying and looking for good places nearby to get comfortable flying. Unfortunately, I live on an acre near the Redwood Coast Regional Airport (ACV) but just outside the Restricted area. Been able to get approval to fly in my backyard.
Looking for ideas of where to fly in Northern Humboldt if there are any Humboldtians out there.
I look forward to being part of this community and learning and sharing!
Marc
First off, I hope Hillary is a non-event for you… I live on the east coast of Virginia and I have experienced several hurricanes and they are not jokes, nor an excuse to have a party. Take all precautions seriously. I know you are in the northern part of the state and it might only be high winds and heavy rain, but we all know how fragile the electrical grid is and you will probably experience power outages.
Don't leave anything out in the yard and have spare water, not just for drinking, but for flushing toilets. (5-gallon buckets are great for that) if none are available, seal the drain in the bathtub with tape and fill it up. It not for drinking, but bathing and flushing. Have spare batteries and all phones charged, be sure you have chargers that will you can use to charge phones from the car.
But as it often happens, if the power goes out, the cell towers only have a few hours of power and by day two, the cell phones are often useless too… And there will be no internet either…
Get an ice cube tray and freeze it, then put pennies on top of the ice cubes and put it back in the freezer. If the power goes out, do not open the frig or freezer to see if it's still cold. If the power goes out and when you do open the freezer and the pennies are now on the bottom of the tray, your frozen items melted and you should use them immediately or throw then out…
Good luck!
But now back on point!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Air 3, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Marc
Welcome! Fellow Californian but not Humboldtian. Happy flying.
Good luck!
This is great info and as a former New Orleanian I agree completely! Humbolt County is almost 800 miles from San Diego though, so I'm thinking he'll be safe. I Am worried about the San Diego area. Looks like it's supposed to go inland from there and could even impact the area around Las Vegas. Heavy rains and the desert don't mix well.
Reactions: LoudThunder
Marc
Greetings my friend
keem21
