Help on CSVVIEW
Gkinghrn
Uk
Was just trying out csvview and i grabbed a coule of DAT files off my Android phone. Installed CSVVIEW on my Mac and tried to read the DAT files i donwloaded.
However I get the following error - no idea where else to ask so thought i would ask here.. Looks like duff DAT file but this has happened with 2 DAT's now...
If you're running 3.7.3 on a Mac you're having the same problem another user is having. I was unable to determine what the problem is - I don't have a Mac. He tried 3.7.0 and it seems to work. Can you try that?
The message about the CRC Error Ratio isn't an error - it's just saying that 2.9% of the .DAT was corrupted. Not that unusual for a MM .DAT
Reactions: Gkinghrn
That's correct. 3.7.3 reads the files but then the sigplayer field is empty, and clicking in it has no effect. 3.7.0 populates with the default set:
Reactions: Gkinghrn
3.7.0 seems to work on the mac but it doesnt if that makes sense ..or am i just crap at understanding it. If i click on any of the sigplayers i see the blank screen here..
I assume you clicked on the Empty SigPlayer. Now click on it's Expose SigPicker to start adding signals to the SigPlayer.
Reactions: Gkinghrn
i think I have something , 3.7.0 looks a bit different but I am in..now trying to figure out what it all means ... thank you
Here's some from sar104's "Flight log retrieval and analysis guide" ...
downloaded : Loaded a DAT file and got this in Terminal
gordons-MBP:CSV GordonK$ java -jar CsvView.3.7.3.1.jar
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: org/jdom2/input/SAXBuilder
at Signals.XmlSignals.readFile(XmlSignals.java:41)
at apps.CsvView.loadSysSigDefs(CsvView.java:573)
at apps.CsvView$CreateCsv.done(CsvView.java:377)
at java.desktop/javax.swing.SwingWorker$5.run(SwingWorker.java:750)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:847)
at java.desktop/sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:857)
at java.desktop/javax.swing.Timer.fireActionPerformed(Timer.java:317)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Timer.java:249)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:391)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.ClassNotFoundException: org.jdom2.input.SAXBuilder
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:436)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:588)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 22 more
There is a test CsvViewMac version 3.7.3.2 at
CsvView Downloads
It's at the bottom of the CsvViewMac downloads. Could someone download, install and run this version? Then send me the .CsvViewLog file. Thank you.
Reactions: Gkinghrn
CsvView Downloads
Still no sig players. I emailed the log to you.
Reactions: Gkinghrn
There is a test CsvViewMac version 3.7.3.3 at
CsvView Downloads
Reactions: Gkinghrn and slup
CsvView Downloads
Fixed.
yep ..although I didnt get any graphs appearing when i clicked on 'empty' ..just me?
Joe Duhr
