Help please! Antenna Install
Zonda89
Hi guys but of help if you wouldn’t mind. I brought a better antenna for my pro V1 and when I installed the new cables it all went fine until I put it back together the 5d button (on the board) had moved down slightly as though the new bolts with the wires going through them had pushed everything down slightly (pause button affected slightly to).
I done it again 3-4 times making sure and then I took the internal plastic centring washer out the bolts even though it looked flush. It looks like everything is fine I’ve looked and looked and can’t really tell where this movement down has come from, all screws line up obviously otherwise I wouldn’t be here.
When I slightly bend the top part to take the pressure of the bolts off all the circuit boards nothing seems to happen it all looks fine but maybe something isn’t quite seated. Sorry that was a lot longer then intended but any help would be much appreciated. It feels like even if I filed down the inside of the control or the bolt head on the thread side the extra couple of mm wouldn’t even matter as when I bend them away they don’t seem to be pushing everything down it’s quite weird, cheers
I seem to remember running into this issue myself, but I just don’t remember exactly what was wrong when I was dealing with it. It’s been a few years ago.
It is an alignment issue with the plastic pieces.
I‘ll keep the gears turning and see if I can remember.
KiKiHUN
