Any thoughts on why my
air2s decided to not come back and went surfing instead?
I am sorry to hear that your drone went "Surfing…" Like the others, I hope you had Care Refresh. You did not give us much information so I'm going to guess that you are relatively new to Droning, so I hope you get your drone flying again and that the following information helps.
mavicpilots.com
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
At DJI Download Center, Learn aboutDJI
Air 2S
www.dji.com
Happy Droning…
