Hi from QLD Australia
bersecti
Agnes Water QLD, Australia
Hi guys n gals,
I was a bit rude and my first post was straight to my first dumb question. So I’ll do the intro now coz I really need to ask my second dumb question.
I have only done a few hours on my first ever drone so ultra noob here. Purchased mainly for an Indonesian surf trip next month. DJI mini 3 pro, Fly more kit, ND filter pack, 1 CPL filter.
I’m aware my footage will be mediocre at best with so little stick time and a learning basics and basic settings before we leave and will bother with editing when we return.
Since you asked the same question in another thread I have edited this one
Hi guys n gals,
G'day, Bersecti, from Rich R in North Texas!
Welcome to the forum. Lots of fellow Aussies amongst our members. Sorry I can't authoritatively answer your question, but I'm sure some of our more experienced droners will provide you some guidance.
Glad to have you with us!
Hi guys n gals,
Welcome from the Sunshine Coast, QLD.
Keep your movements slow and steady and minimise gimbal movement. It’ll make your footage look more professional and easier to edit.
Unless you are familiar with the use of neutral density filters for video, best leave them in the box. If you are familiar then aim for a shutter speed of 1/50th sec.
The CPL filter will be of less use for video. As you move the drone around it will lead to an obvious difference in the saturation of the sky - assuming clear skies.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
rejuwa
