- Joined
- Oct 12, 2016
- Messages
- 28,328
- Reactions
- 31,188
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
A new firmware update was just released to add RID support to the Mavic 2 Zoom. See more details in the release notes here.
While installing firmware updates is optional (nothing new there), the release notes are warning you that the new firmware will only work with DJI GO 4.3.60 (or higher). So, if you want to install the new firmware, you also must install DJI GO 4.3.60.The firmware release notes include overt threats to block access to DJI Go 4 for recalcitrant Mavic 2 owners who may be tempted to politely decline the latest firmware "upgrade"
This clarification is appreciated. I regard firmware updates with the same trepidation I reserve for dental visits. In both cases, I'd rather not unless there is no way to opt out.While installing firmware updates is optional (nothing new there), the release notes are warning you that the new firmware will only work with DJI GO 4.3.60 (or higher). So, if you want to install the new firmware, you also must install DJI GO 4.3.60.
And then there's nothing to ponder if you don't want to install the new firmware.
Yes, and that's usually where most people are install firmware updates.Can the updates be done inside with just an online connection
does this work on a smart controller?While installing firmware updates is optional (nothing new there), the release notes are warning you that the new firmware will only work with DJI GO 4.3.60 (or higher). So, if you want to install the new firmware, you also must install DJI GO 4.3.60.
It does, I installed it last night and flew today and it works great. I have no idea if the remote ID is working, but it is in the settings now (and turned on by default). Make sure to reset RTH altitude and check all your settings because several reset to very low numbers.does this work on a smart controller?
does it give the option to turn off???(and turned on by default).
Yes, there's a switch for UUID and one for flight information.does it give the option to turn off???
are any other dji drones able to disable rid?Yes, there's a switch for UUID and one for flight information.
Don't know, I didn't try switching it off. The switches are enabled on default, maybe they don't actually turn off I'll have to give it a try. It's a switch just like the one to enable/disable flight modes.are any other dji drones able to disable rid?
So I was excited to hear that DJI had finished the update ahead of schedule. However, when I went to update the firmware for my M2Z via the DJI Go 4 app. it says I am up to date at version 01.00.0670. I have restarted everything a couple times and the app does the firmware version check and states that it is the latest version. Anyone else have this issue?A new firmware update was just released to add RID support to the Mavic 2 Zoom. See more details in the release notes here.
This is not the same as the FAA Remote ID, and does not comply with FAA rules.Yes, there's a switch for UUID and one for flight information.
I was having this exact same issue with my Mavic 2 Pro. I'm not sure which of these things fixed the problem, but I realized I wasn't logged into the DJI Go 4 app. Click the "Me" button on the lower right of the screen and make sure your userid shows up and if not log in. I also completely shut down my Ipad Mini, and restarted it. After doing these two things, the firmware update now appeared and completed successfully. I hope this helps.So I was excited to hear that DJI had finished the update ahead of schedule. However, when I went to update the firmware for my M2Z via the DJI Go 4 app. it says I am up to date at version 01.00.0670. I have restarted everything a couple times and the app does the firmware version check and states that it is the latest version. Anyone else have this issue?
Running DJI Go 4.3.60 on iPad Mini 5 w/OS ver 17.1.1 using the standard controller.
A/C ver 01.00.0670
Remote Cont ver 01.00.0640
all Fly databases report latest versions
Thanks
So it looked like I was signed in. I logged out and then back in and finally got the firmware update notification! Thanks so much for your help! That never would have occurred to me.I was having this exact same issue with my Mavic 2 Pro. I'm not sure which of these things fixed the problem, but I realized I wasn't logged into the DJI Go 4 app. Click the "Me" button on the lower right of the screen and make sure your userid shows up and if not log in. I also completely shut down my Ipad Mini, and restarted it. After doing these two things, the firmware update now appeared and completed successfully. I hope this helps.
