Mavic new Pilot, Few problems and questions....
Kikinen
Hello Everyone
I'm obviously a new Mavic Pilot, and new on this forum and I have few questions and problem around it, I try to find my answer on this amazing website but I didn't :
- I can not connect my Iphone with a regular Iphone cable via the classic usb under the remote, It will be perfect to fly with a VR goggles but the connection do not work ? anyone got a tricks ?
- I fly in the mountains so I need to go high, not far, not high from the ground but high in altitude, with DJI Go App I can go at 500 meters height, everybody says that I can unlock the height restriction with Litchi, but it's the same thing, I can not go over 500 meters.
- I get battery alert in Sport mode.
- Cinématique mode, I do not understand how the focus works in this mode.
otherwise I'm very happy with this drone, best one I ever had....
Thanks for anyone who will take time to help and answer my problems
Kiki
..- I can not connect my Iphone with a regular Iphone cable via the classic usb under the remote,... anyone got a tricks ?
Unplug the upper USB cable from the side of the remote first. You cannot even have a disconnected lead in the upper port as doing so disables the lower one data use.
You cannot flight any higher in Litchi that in you can DJIGo. the firmware prevents this very sensibly. Climb to a higher point before you launch. Alternately get your self a drone that is designed, certified and legal to fly above 500m AGL.
Fly slower or switch back out of sports mode
Someone else can answer this as I have not used it.
gonzoales
