sar104 can you confirm on 100% that you don't have this issue ?
I don't get any error messages, i will try to dwonload and see logs but boubt to find anything.
I dont have this issue...Many times, you don't have this issue ?
Mine also has a slow drift to the left. it usually goes away after 20-30 sec. I checked the Attitude Yaw, RC rudder and Gimbal Yaw in the logs. They are all behaving normal. maybe it's some compass or IMU drift. haven't calibrated them for a long time because the app never asks.
On my last flight I did have the drone bounce like the tello bounce mode.... It was moving up-down ~50-60cm without any inputs. Only at low altitudes. In the logs the height shows constant, but the sWaveHeight shows the bounces clearly and the throttle is not causing this.
sar104 do you help me analyse the logs if i put it on some public drive ?
My brand new mavic pro suffers to yaw drift i can replace it to another one but are there any mavics free of this error?
Thanks, you can download logs from this linkSure - and there are several other members here who will likely take a look.
DJI_ASSISTANT_EXPORT_FILE_2018-03-27_22-08-43.DAT and 1 more file
Are you saying that the yaw value is not changing, even though you can see that the aircraft is rotating?
It suggests to me a gyro calibration problem, but you mentioned that you have calibrated the IMU - correct?
