Minor propeller damage: safe to fly?
szh
I noticed minor damage on one of the propellers. There is a slight bend at one point which I cannot unbend. It is present on both blades, around the same area.
I am not sure how it got there. It was either pressed during transport (unlikely, as I was careful), or it happened when I accidentally clipped a single stem of tall grass during landing (although I did not notice this at that time: I cleaned off the propeller and it appeared fine).
I have flown with this propeller at least twice, and I did not notice anything strange (such as different propeller sound). The damage looks very minor. But I am nervous about continuing to use it because a propeller failure would mean losing the entire drone. Perhaps it can lead to vibration, or there are invisible micro-cracks ...
There are no scratches or cracks visible around the area, only a bend.
Would you fly with such propellers, or replace them?
Reactions: butterflyslicer
All good advice....
I'm interested in how this might happen, which blades are damaged, the front two for example. Would you say it's impact, or warped, or heat damage. I assume they are standard stock props.
A pair of propellers costs less than $9 in the U.S. I would replace them.
I agree with Mr.Salty.. with how cheap they are why take a chance.. on the other hand here's a good video on prop damage..
The props are kinda your lifeline. I would not risk it extensively flying with those props. Even if they perform sufficiently they definitely will stress the bearings on your motors. I admit €9 bucks for two props is a nasty price but... the lifeline thing
Reactions: BigEegit
It would be nice for those that have data on battery assessment to look at how much of a damaged prop is required to cause an extra load on the battery by the motors having to work harder
antifragile
