I'm just just wondering if it's been stated or if anyone has determined what the most efficient speed is for the longest possible flight times?
Longest flight *time* is definitely tripod mode. Longest flight *distance* is a different matter.
Interesting I just hypothesised in my head. Once again (similar threads lately) very interested to see data on this stuff and the optimum speed for distance.No - not zero - hovering takes a lot of energy. For instance note that a helicopter has a max hovering altitude that is lower than its max land/take-off altitude.
0kmh for flight time I would imagine
Cool, Do you remember where that was answered?This was actually answered by DJI, i believe it’s 14km/h for the 34 minutes advertised time
Makes sense, similar to boatsA helicopter, or multi-rotor, is most efficient in directional flight (Translational Lift). Hovering in place takes much more energy due to turbulence and vortices which get left behind as the flow of air becomes more horizontal.
Also, it makes no difference which way the wind direction is coming from. Aircraft fly with respect to a moving air mass, which to the aircraft, looks stationary. The only thing that changes is ground speed. Airspeed is the same flying with the wind or against the wind. Some folks have trouble grasping this concept…
Instead of guessing, all you have to do is look at the specs.Cool, Do you remember where that was answered?
I understand the principle but have difficulty grasping what you are trying to say.Also, it makes no difference which way the wind direction is coming from. Aircraft fly with respect to a moving air mass, which to the aircraft, looks stationary. The only thing that changes is ground speed. Airspeed is the same flying with the wind or against the wind. Some folks have trouble grasping this concept…
A J3 driver quickly learns all there is to know about winds aloftSome folks have trouble grasping this concept…
I’m not convinced. 34 minutes at 18kph (5m/s) is 10.2kmInstead of guessing, all you have to do is look at the specs.
Max Flight Time 34 mins (measured while flying at 18 kph in windless conditions.
The Max distance will be very close to Max speed in N mode with OA disabled.
Not convinced about what?I’m not convinced. 34 minutes at 18kph (5m/s) is 10.2km
whereas say 20 minutes At 43.2 kph (12m/s) is 14.4 km that’s sports mode and I think that’s doable I reckon you could get up to 24 minutes (17.28 km )but that’s just speculating, mind you I’m pretty sure there are range tests in the high 9 km’s mark on YouTube confirming at least 18km.
so with no intention to be contrary but I do think we have to speculate the most efficient speed for distance. It would be around 12-15 m/s I guess.
Sorry 12 m/s is normal mode. 20 minutes easy bThere is no way you’ll be getting 20 minutes of flight time with full throttle all the way in sports mode. You can see that for yourself, takeoff with 100%, full throttle in sports mode, keep it like that for 10s and then check the estimated remaining battery time in the top right corner.
