My Incredibly Easy and Free Way to Mount the 5.5 Crystalsky to the Mavic Pro Controller
kenzenichi
Given the expensive and / or elaborate solutions to mounting the 5.5 inch Crystalsky to the Mavic Pro controller, I'm a little surprised that no one has tried this:
Simply removed the three screws from the bottom of each Mavic controller arm and slide the rubber feet out. The added width is absolutely perfect for fitting the monitor snugly. I hope this helps some of you.
Cheers.
-Kenn
Reactions: 2ducks and AMGKid
Cool. Does it not slide out without the rubber?
Given the weight of the monitor, I wouldn't go flailing about one handed but it really is quite secure. You would have to shake / fling it violently to get it to come free. My controller is brand new (my first drone) and are pretty stiff. I'm not sure if they loosen up over time and if so if it will effect their reliability to hold the monitor. But for now I am very happy with the setup.
Good thinking Kenn.
I did the Velcro method
Reactions: Chappy937
A try.
Currently also use the velcro solution. Your solution is cleaner
Looks like a disaster waiting to happen to me.
Maybe the cable will stop the fall but I wouldn't count on it with the weight of a CS.
Reactions: Johnnyaibo
I'm not sure that looks to be secure enough ...
This was the version I went with in the end having tried a few other mounts.
It doesn't come with the screws? Either way I'm going to order.
dojin23
