The ADS-B option is under advanced settings under safety. It's at the bottom called "AIRSENSE". It only has one option, On or OFF.Can you change your sensitivity level as it might be picking up planes 30,000 ft and than are out of your area,
Phantomrain.org
Gear to fly in the Rain.
Ok, Same setting my Classic M3 , on one of the drones they do have a Sensitivity rating , sadly its lacking on the M3 series.The ADS-B option is under advanced settings under safety. It's at the bottom called "AIRSENSE". It only has one option, On or OFF.
I've experienced this as well and your thoughts seem to make perfect sense.On the map view, tap the plane icon. That is where the sensitivity options are. I do believe that ghost happens when a craft is at marginal range and the signal is perfectly aligned with the drone for a few seconds. Then the signal drops out as both craft move.
