new dji pilot
Welcome to the forum! :)
Welcome, personally I'd leave flying in the rain for the moment. You have a flying box that is full of ventilation holes and electronic wizardry. I don't think water and 'naked', powered electronics mix very well.
That's just my thoughts, others may feel differently but at the end of the day it's your drone, your wallet and your choice.
@SonofFred firstly welcome to the forum
as others have mentioned flying in the rain or indeed in moisture laden air, is not really a good idea
water and electronics do not good bedfellows make
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many from Hawaii--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
the mini 2 is my first drone
Just remember, Superman can fly through Trees, your Mini 2 cannot...
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Hawaii, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
brokerman
