I have been flying DJI drones since 2013 and haven't had any issues to date (knock on wood). I've owned the Phantom 1.1.1, Phantom 3 Advanced, Spark, Mavic Pro, Mavic Air, Mavic 2 Pro, Mavic 2 Enterprise Dual, Phantom 4 Pro and Inspire 1 Pro. DJI makes a quality product, follow a pre-flight checklist, know your surroundings and get to know your equipment. The Mavic Air is an excellent machine.Hi all,
I just got my first drone, Mavic Air. I am nervous with all of the settings in the DJI go app and reading here about so many problems! Does anyone have an Air that has had no troubles? Thanks
Thanks! I have a couple of questions, one is can I power on the RC and familiarize myself with the icons without powering the drone? and second, I found a label on the drone with wifi SSID and password. what do I use those for?first off down load the manual and absorb the info in it, one of the great things about DJI drones, is the fact that many of the flying parameters for controlling the drone can be fine tuned in the app ,but with that ability it is possible to cause issues if you do not know what a particular setting does ,dont change any of these settings till you fully understand what effect they have on how it flies,start off in beginner mode until you get confident in controlling your drone, if possible find someone local to give you help and advice on the different settings also there are some good vids on the internet and of course come on the forum and ask for advice
Hi, thanks for the response! What is the purpose for the wifi SSID and password on my craft? Do I have to enter that somewhere, DJI go 4 app?I have been flying DJI drones since 2013 and haven't had any issues to date (knock on wood). I've owned the Phantom 1.1.1, Phantom 3 Advanced, Spark, Mavic Pro, Mavic Air, Mavic 2 Pro, Mavic 2 Enterprise Dual, Phantom 4 Pro and Inspire 1 Pro. DJI makes a quality product, follow a pre-flight checklist, know your surroundings and get to know your equipment. The Mavic Air is an excellent machine.
the wifi SSID is to enable you to control the drone from a phone or tablet using WIFI it gives you a restricted distance and height similar to beginner mode you do not need the controller to use this featureHi, thanks for the response! What is the purpose for the wifi SSID and password on my craft? Do I have to enter that somewhere, DJI go 4 app?
ah, got it! thanks for helping! can I play with the RC to familiarize myself with it without powering up the drone?the wifi SSID is to enable you to control the drone from a phone or tablet using WIFI it gives you a restricted distance and height similar to beginner mode you do not need the controller to use this feature
if you want to familiarise yourself with the app make sure to have everything charged up leave the props off the drone and make sure you have removed the gimbal locks have it sitting arms extended and go through the start up procedure until everything is turned on and linked then you can look through the different icons in the app and set your preferences dont worry if the fans in the drone or the controller start this is quite normal if it is fairly hot where you are you can employ a cooling fan to assist with this process have the manual handy to refer to so you can see what the icons do
I was worried about hearing the cooling fan having the drone sitting in front of me on the table while I was playing with the RCthe wifi SSID is to enable you to control the drone from a phone or tablet using WIFI it gives you a restricted distance and height similar to beginner mode you do not need the controller to use this feature
i may have misled you i do not have a mavic air my answer was for a mavic pro platinum sorry if i have confused you, not sure how the air is connected to your screen does it have a cable from the controller to your screen if it does then it is the same as the MPP sorrythe wifi SSID is to enable you to control the drone from a phone or tablet using WIFI it gives you a restricted distance and height similar to beginner mode you do not need the controller to use this feature
dear @ cjhc look at the thread, Mavic air after 18 months full-set up tutorial and more useful stuff
Most of the problems are caused by the people who fly them. You can prevent many of them by following the tips in this guide:I am nervous with all of the settings in the DJI go app and reading here about so many problems! Does anyone have an Air that has had no troubles?
