Anything I should look out for in particular or any calibration (or other) action I can take to test it out fully?
Welcome from the Hampton Roads area of Virginia, USA. I fly a
Mini 2 and I know the excitement you are going through…
If you are in the U.S.A. there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
If you live elsewhere, be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Drone Flight Application Strategy Digest, continually updated!
The following YouTube Video by Jeven Dovey is well worth watching and you might even subscribe to his channel…
Below is the link to all of the downloads offered by DJI for the
Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
