Novice from Atlanta, GA
drfoto
Atlanta
Hi everyone. Experienced photographer / inexperienced drone pilot-photographer. I bought the Mavic 2 Pro several years ago and can fly basics but haven't really explored visual creativity as much as I should have. I'm headed back to Iceland this summer and want to shoot some braided river stills (composites for high res). I updated the drone to enable RID, which shows on the RC display. I was hovering in the front yard today to test battery life (disappointing in original batteries that weren't routinely charged) and tried the Drone Scanner app. I had hoped to see my drone as detectable, but unless I'm doing something incorrectly, it is showing up. I was only hovering 8-10' off the ground. Is there a minimum height for detection? Any suggestions I should explore?
Thanks, Mark
Greetings from Birmingham Alabama
Welcome to the Forum From Bakersfield...Try a Different app those apps are "buggy" you may see the drone you may not.
I use a Ruko RID Module and the Drone Scanner App works just fine, just make sure you enable the Bluetooth and WiFi on your device (phone/tablet, etc…). The App Scans for Direct Remote ID signals using Bluetooth and Wi-Fi.
Since you are not a regular and current Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum @drfoto! :)
No.
As long as you have aircraft firmware version v01.00.0797 installed, RID will start transmitting as soon as the motors have been started.
Thanks, Mark
Welcome to the forum from the UK!
Thanks, Mark
After reading responses about Drone Scanner and Bluetooth (iOS) vs WiFi (Android) I installed the Android version on the newish Android phone I keep around for occasional use. No joy from the Android Drone Scanner app either. The remote ID is displayed in the DJI RC controller, which contacts perfectly with the updated Magic 2 Pro. I also don’t see a WIfi network on the iPhone under BT networks as sugggested elsewhere as a way of confirming broadcast of RID. I want to nail this down before Iceland. Any other suggestions? Something that needs to be enabled and isn’t? Thanks.
There's nothing to manually enable. Just start the motors and you're good to go.
It sounds like you've already nailed it down since the remote controller is displaying the remote ID info.
Thanks for your comprehensive post Loud. Did TRUST and FAA registration when I first bought the M2P several years ago. Just renewed FAA to acquire RID number for updating M2P which was successful, so good to go except for wanting to confirm RID broadcast. No point in being registered but out of compliance by not knowing for a fact you’re in compliance. 😉 Also passed TRUST equivalent and gov registration in Iceland. I did appreciate you mentioning the Atlanta Fly Map which is useful. Cheers and continued success. M
As I wrote, I use a RID Module, not associated with the drone. I can attach it to my cat's collar and follow my cat's wanderings with my android phone.
As for your RID number being displayed on your controller, I cannot say it is receiving the information from the drone or it is merely reporting it from a database.
I would just make sure that the drone is in actual flight and your phone has it's WiFi and Bluetooth enabled.
I would also try several other Drone Tracker programs.
After I wrote my last posting, I went out and performed some test flights and here are the results…
As I wrote previously, I am using a Ruko 111 RID Module as my drone cannot be upgraded. Aside of the cost, about $30 and a few grams of flying weight, there is little of no effect on the drone's performance.
One advantage that I like is that the Ruko RID Module has a 5-hour operational duration. If my drone goes down in a tree or field (out of sight in tall grass… etc…), the drone's battery will only transmit "Here I am…" and buzz it "feeble buzzer" for the duration of the drones battery, which might be nearly depleted. The RID Module will continue to transmit for hours…
additionally, if the drone goes down and it's battery is knocked loose or the drone is severely damaged, it will not be transmitting it's location, but the RID Module should continue to sometime…
I use the Drone Scanner App available on Google Play in my Motorola Moto G Power, Android, Phone, and this morning I took my drone out in my yard and screen shot the App's readouts…
In the Map display, Arrow "1" (Blue Dot) shows the launch point of the drone (or where ever it is first turned on…). Arrow "2" (Green Pin) shows the Drone's location. And Arrow "3" (Blue Circle) shows my location in the yard. The Red Eclipse shows the bands my phone wa receiving its date (both WiFi and Bluetooth…)
The App will also show the flight path (Blue Line) but in this small space, I turned it off so it did not obscure the above information.
Below is a multi-screen shot of the read out if you were to scroll through all the displays.
Reactions: Hauptmann
OldGitRay
