I disagree. I feel the test is valid under those specific circumstances. However, another set of circumstances, like flying in a WiFi rich environment, may produce a different outcome. ??
I said it may be different. Someone will have to try it and see.How will it be different ?
It's just simple physics. Given a level of interference, the stronger the signal, the further the distance. The effectiveness of the reflector in extending the range is still there.I said it may be different. Someone will have to try it and see.
I just got the Yagi yesterday and I was windy but a mile out was perfect reception and I get a lot of interference here at my house.Does it work better with both??
If you have got the FCC version, it's running on 5.8GHz only.How many millimeters from the top of the antenna's should those yagi's be mounted and is it different between the 2.4ghz and 5.8ghz yagi's?
I read somewhere he middle of the metal rods should be 28mm from the top of the antenna's, but I'm not sure whether that was for the 2.4 or 5.8
