Rebound on left/right yaw during course lock.
mpatts
I was out flying today, testing some new settings and I found an issue with my yaw while in course lock. If I gave a little input to try and turn left or right it wouldn't turn as much as I expected. When I let go of the stick it would rotate back the direction it came from. I couldn't get a smooth turn because it was fighting me the whole time, I had to push almost all the way out to get it to rotate how I expected.
I have my yaw settings turned down in EXP, but if I turn course lock off, it works perfectly fine. I have the gimbal assist yaw setting on too. I didn't think of that until just now, I'll test later if turning the gimbal assist off will fix the issue.
Any thoughts?
Any thoughts?
Did you have any luck with the above issue? I tested course lock for the very first time and faced exactly the same behaviour. Is this normal? I also have minimised yaw input at the EXP settings for smoother turns.
Any further posts or thoughts on this? Having the same problem with Mavic Pro 1 in November 2021.
Many thanks.
Lorin
YT360
