SC latest version bug?
Dakrisht
Southern California
Running the latest version of the SC FW but just noticed a rather weird bug.
When tapping the Switch Aircraft button from the swipe-button screen, I don’t see anything but an empty box.
Before, you’d see all of your aircraft here with an icon so you could easily swap between one or the other.
Anyone else seeing this in their smart controller? You don’t need to have multiple aircraft, but simply tapping the icon should show your main drone paired up or remembered.
I had to relink my M2P... The new M2Z stayed linked...
But I noticed when I switch aircrafts the histogram disappears and you must toggle it off and back on.... Tried it a few times and it's a bug too.
What are you toggling off/on?
I just don’t see my M2P or M2Z in the user interface like before. The entire box is empty so seems like a bug.
Might hard reset and go back to the previous version.
The histogram on/off is what I needed to toggle but it's not the issue you described
I had the missing aircraft too. I re linked it and then it appeared in the list with the other.
Mooseknuckles
