Smart Controller Switching issue
skyhigh9021
ontario
I have the SC paired with a few Mavic 2 Pros, Phantom 4 Pro and a Mini 2.
I can switch from the Mini 2 to the M2P and P4P fine BUT everytime I try to go M2P/P4P to the Mini 2 it doesn’t connect and gives the error ”Connection Timed out”. The only way to connect is to relink the Mini 2.
Anyone else have this problem? I have tried re-linking even renaming the mini 2 on the SC but the issue persists.
Reactions: halifax
Yes, same issue you described. My guess is they haven’t smoothly worked out how to transition between DJI Fly and DJI Go4. I’ve been doing as you described - re-linking.
Fortunately, once linked the name is recognized. I was dealing with this a few times yesterday and came here today to see if anyone else was having the issue and whether there is a simpler approach.
I’ve only been successful switching between the M2P and all DJI Fly drones using Aircraft Management in the SC settings using the re-linking approach.
Reactions: TampaTC
I have the M2P and the Air2S and the SC. Seems I always have to re-link when switching. A bit annoying, but it does seems to always work, which I am grateful for,
Same here. Always have to re-link when switching.
jhon65
