Strange Battery situation with my M2P
ToddCarey
FAA Part 107 Certified
Mooresville (Lake Norman), NC
I went to fly today, charged two batteries, but the first battery had a full charge (by the ring), yet the drone noted "The remaining battery is only engough for RTH. Return home now". On the screen the battery has an N/A. yet the battery ring is still showing a full charge. The battery has absolutely NO swelling and snaps in well into the drone. See pictures below.
Right now I have removed the props and are just running it20210519_155511[1].jpg20210519_155518[1].jpg to try to drop the battery to about 1/2 charge, and then charge it up again.
Any comments?
I will check and post the dat file once I let the battery run down a little more. Is that something that can be corrected, or is the battery dead. I have plugged it in and removed it several times....
It doesn't sound promising but I would not give up on it yet.
sar104 - Thanks for your assistance. Here are the two flight records from yesterday. I assume the real small log is where I started it up, but could not do anything as the drone thought the battery was dead.
  • DJIFlightRecord_2021-05-19_[11-42-09][1].txt
  • DJIFlightRecord_2021-05-19_[11-55-21][1].txt
Oops, those were not the dat files. The flight one is to large, but this is the one with the bad battery (I think)
  • 21-05-19-11-39-17_FLY024.DAT
SK farming
