kcoleman805
Just took my Mavic for a flight using two batteries. Finished flying and brought my Mavic inside to charge the batteries. I placed my two batteries into the charging dock, as I usually do, and when I did so the light on the charging dock went red. And the green light closest to the power switch would blink 3 times, and then again and then again. So I took them off the charging dock and tried to just charge them individually to see if that would work, and the same thing happened, 3 blinking lights from the light closest to the power button. I have a third battery and tried to charge it and it worked fine. The two batteries that are having issues are the two I just used to fly with. What is the matter? Please help! Thanks!
Yeah, probably hot battery. Since summer came around I leave them out of the case for a little while after flying and let them get some airflow since they won't cool down in my bag.
Reactions: kcoleman805
When they're too hot they won't charge. Just leave them in the charger. They'll eventually start charging on their own.
tortoide
