Use of ipad with mavic mini
Mike Baird
I am interested in buying an IPAD to use with my Mavic Mini. Which IPAD will work the best. IPAD 5? Is cellular service necessary?
Cellular service is not *necessary*, but the cellular-capable iPad mini 5 has GPS onboard, while the non-cellular iPads lack the hardware for GPS.
I've been using an iPad mini 5 cellular without a cellular plan. Works fine.
Reactions: Mike Baird
There's not much use for GPS on the tablet, the drone uses its own GPS recorded for flight functions.
Other than the directional indicator in DJI Fly, and resetting RTH on-the-fly, you are correct.
I primarily use the GPS on the iPad for APRS functions while I'm out chasing the weather.
If you want the online maps to work, you need a cellular or WIFI connection. You can cache the maps before you go out, though, then you don't need the connection. But the drone flies fine without Cellular/WIFI as others have stated.
Ipad Mini 5 would be the best if you want an 8in screen size
deauxpamine
