Vision system error
ceo_acm
Manchester
Hi guys anyone now how to fix this issue I have for vision system error saying downard right vision sensor error (2) IMG_8299.JPG
If a restart of everything doesn’t fix it I’d try a reflash. Failing that follow the onscreen instructions in your pic.
Reactions: ceo_acm
You can try OA recalibration using Assistant 2 with a PC. The calibration process shows what the camera being calibrated is seeing.
Reactions: ceo_acm
Hi jus tried this but completed the calibration and then a error came up saying unable to detect calibration image so goin try diffrent laptop as I did it on my Mac
But during the calibration phase for the bottom sensors, did an image from the camera appear?
Granted the image shown could be from the working camera, but if it doesn't appear, then there's a good chance it's a hardware issue.
Thanks Dan all sorted still got the error coming up after I finished calibration but then I decided just to connect controller and dgi go 4 and boom the warning gone :) thanks for your help much appreciated
Reactions: Bobvt
This is probably a long shot, but is there any dirt on that sensor?
The error just come back on again might try calibration again
When you calibrate the sensors you have to calibrate all the sensors top,bottom.sides,front.back and make sure you go through the whole process and it say complete
Reactions: ceo_acm
I did it last nite came up saying complete tried it and no visible errors turned it on this morning and it back on again? Grrrrr lol
tyroe1998
