I use a Sandisk extreme 64gb. It has 1hr 24mins capacity of 4K hq 30fps 10bit d-log, as a reference point.
Yes -- if you're shooting 4K. See more details here.They need to be "U3" correct?
I’m not sure on that term uhs1/u3 and what not. I do know it needs to specify that it has a minimum write speed of 100mb/s though. Any of the name brands will give accurate info for that.
Read speed isn’t as important.
The Mavic 2 is only able to write data at a max speed of 12.5 MB/s (100 Mbps).I do know it needs to specify that it has a minimum write speed of 100mb/s though
I think you have your Ms and Bs mixed upmb/s vs mB/s
The M2 is only able to write data at a max of 12.5 MB/s (100 Mbps). So, all U3 rated memory cards should allow for optimal performance.sounds like it's not critical to achieve the 100MB/s write capacity of the M2
Agreed, that’s what I wrote
mb/s vs mB/s
Do memory cards use the true bit to byte conversion (8) or the dumbed down (10) scale?
LOL msinger you are so right - I was getting my b's and B's mixed up!The M2 is only able to write data at a max of 12.5 MB/s (100 Mbps). So, all U3 rated memory cards should allow for optimal performance.
Careful of the minefield that SD card spec's are ...Interestingly, Sandisk Extreme 64GB U3 are rated to write at up to 60MB/s. You need to go up to 128GB to achieve up to 90MB/s performance. If people here have been happy with 64GB cards, sounds like it's not critical to achieve the 100MB/s write capacity of the M2 as long as the card is 4K rated (which U3 is). Comparison chart here: Extreme® microSDXC™ UHS-I CARD | SanDisk
