Did the fw update, with one battery in. When I place the second or third battery in, there is no indication to update the other spare batteries firmware. I'm confused is there fw for the Batts?
did you turn on the ac as directed after the update had been done you then need to turn ac off turn controller off put a new battery in the ac turn on controller and then once it had connected to the device turn on ac and wait for the blue go fly to appear on the screen and then you should see a message that new battery firmware is available touch inside the box and it will download the update then do the same thing for your other batteryDid the fw update, with one battery in. When I place the second or third battery in, there is no indication to update the other spare batteries firmware. I'm confused is there fw for the Batts?
Curious, is the MM battery manage by own firmware,? since day 1 i got the MM but never ask for batteries firmware update,i have 4 batteriesDid the fw update, with one battery in. When I place the second or third battery in, there is no indication to update the other spare batteries firmware. I'm confused is there fw for the Batts?
Than im lucky ,i got the batteries are ot require firmware update ,my AC/RC firmware version updates to 400 from 200you will only be asked to do a battery update if the firmware update has any bearing on the batteries, in the new update it mentions the batteries with regards to displaying no of charges, so therefore that means the battery needs to be updated as well
Got it. Thank you!When upgrading the firmware of MM, battery's (the one which is plugged in) firmware is upgraded as well. The two remaining batteries (I own Mavic Mini Combo) once plugged in - caused that DJI Fly app informed about "firmware upgrade".
Good tip! Thanks!For some reason I had to completely exit the app and restart it then it would ask me if I wanted to upgrade the firmware in each battery. I would turn off MM put in new battery, power on and it would not ask me to upgrade battery regardless of how far back/forward I went in the app. I closed out the app and starrted it again and viola - it asked me if I wanted to upgrade the battery.
