Best quality Mavic 2 Pro Skin supplier UK?
Brelsh
I'm in the UK and really want to make my drone stand out from the 'cloud' lol but really I can't seem to find the bloody thing half the time. Also I'd like it to look more like a work object/tool to fit in with it's use so if you have a recommendation please comment
Mucho thanks
Reactions: Bill combs
Mucho thanks
check out the decal girl
Reactions: Brelsh
Yeah, decal girl has some decent wraps. If you looking to get better visibility of your bird while flying, wrapping it even in the brightest skin will not make any difference. I would suggest a strobe light for that purpose.
Reactions: ff22
I would agree. I went with four Strobon strobe lights. I added little 'strong' velcro pads to the four arms and matching pads to the lights.
Reactions: Brelsh
Wrapgrade is far and away the best skin manufacturer. They are more expensive, but quality is better.
For lights I recommend Firehouse ARC2, one on each arm. In heads to head testing ( video posted on the forum somewhere) they are clearly brighter and visible at greater distance than Strobon.
Here’s the comparison:
Reactions: Brelsh
Not sure if they fulfil your brief for them to make it look more like a tool but this guy’s wraps are really good. I have the Dirty Gulf one and it’s brilliant.
Reactions: Brelsh
Mucho thanks
You might want to consider a Mavic Wet Suit for a nice look and some added functions.
Sent you a Pm.
Phantomrain.org
Coal
Reactions: Brelsh
I had both - Decalgirl and Wrapgrade - and prefer the latter.
For visibility, a neon colored skin helps marginal (mainly when flying with a dark background as e.g. trees). For me good to ~300m.
The strobe lights help more (have Strobon and Arc II). Arc II works for me midday ~500-700m and at dusk ~double.
In the forum I read that a reflective skin or label will reflect even brightest sunlight so one can spot the drone when spinning it. This sounds logic and I need to try next.
Reactions: rayrod354
I got a 3M vinyl sheet from eBay. Downloaded a cut file posted on here, cut it with a cricut machine and wrapped it myself. Easy peasy.
Reactions: Brelsh and Thomas B
PFCKW
