Bought and Tested the DJI RC Plus on Ebay that claims to work with the Mavic series of Drones. Guess What? IT DOES WORK! I'll tell you why.
did the dji fly app version overwrite the previous version without the need for any un install?
Where did you find the fly app apk?
Could you outline your Install steps if you would be so gracious
The fly app version the controller just came with still has geo fencing. 🤬
Thanks
I just bought and received one of these eBay RC plus controllers
I am leery as to what can be updated and updates to avoid as it may brick, this special modified RC Pro firmware
I see there is a small nag message to update the firmware on the controller. I am assuming this would be the firmware update, which would be referred to as the kiss of death??
Go into the "Profile" settings on the controller. Slide the slider to the left where it says "Automatically Check For Updates" That applies only to the controller firmware. Yes, do an update for that and you've got a 600$ brick.
can someone verify that it is OK to update the DJI fly app from within the fly app updating method?
Yes, did that last week without a hitch
I see a new DJI fly app release date March 31, 2025. Are any of you guys running that version with the eBay modded RC plus.
Yes
Are we able to update the DJI fly safe database without issue
Probably can, but I hardly ever update that anyway
I am wondering if I turn off the Wi-Fi connection will I still get that nagging prompt to update the firmware? I am fearful one day I may hit install out of habit
Follow the instructions above, you won't get popups anymore
Any thoughts or recommendations on this topic?
Thank you for any information you may be willing to share most appreciative
Thanks for all your help!! RC Plus is all set up running like a Ferrari!
Could not have done it without your info sharing!
It's just a great, powerful controller isn't it?
Were you trying to show something?
I was trying to post s photo of my plus controller running fly app ?? Not sure if I am posting correctly
Hi,
but why? We now that he works with the flight app
So, I've had this RC Plus for better than a month now. People getting upset about non-working buttons don't understand. They don't correspond to buttons available to the RC Pro controller anyways. So, I didn't lose anything as far as use goes. Installing a different firmware? No difference when it accomplishes exactly what I wanted it to do. Run a better overall controller when considering the 1200 nit display, the larger, higher resolution display? Yes. Extra battery for longer use between charges? There's no downside to using one of these that I can see.
Reactions: wrybread
Hi Rester1505,
you are completely right! I don't need the Button, the Controller is really Top! Better as the original Controlller from the Mavic 3 Pro, as the Pro Controller, bigger better Display faster , 1 word PERFECT!
Reactions: wrybread
For those that have recently purchased one of these controllers for your Mavic 3, This might be a dumb question: you say the R1, R2, R3, C3 buttons don’t work, but what about the L1, L2, L3 and other scroll wheel?
I feel like the answer is that it doesn’t work as this controller is essentially a RC pro controller, but I just wanted to confirm.
I ordered one, but mainly because I heard it works with air 2s and DroneLink and it’s got a bigger screen and better battery life. It’s essentially an RC Pro with a lower price tag and a bigger body.
- way bigger and brighter screen than the Pro
- way more rugged and waterproof
- with the hot swappable battery way more battery capacity
- twice the storage
- detachable antennas
I could go on. But yeah, calling it merely a "bigger body" is missing the point by just a little bit.
- twice the storage
Could you confirm my answer to my own question thought about the front buttons? Please.
my bet is it is dependent on the body that software thinks it is in. If it is not present, then that software would have no reason to look for it.
They aren't hacking up the software. They simply figured out a way to get software from one rc to sideload into another is all.
That’s why my assumption is that it won’t work but I’m curious why every stated listing only says R1, R2, R3, and C3 doesn’t work - that still leaves the L1-L3 buttons. But maybe I’m reading too much into it. It’s not a big deal either way as the Mavic 3 Pro doesn’t need the extra buttons for any function but still curious to hear from one the guys that has one.
Reactions: High_Order1
fluro78
