Can not access the intelligent flight modes! PLEASE HELP!
tonimaker
Hi there! I've had the Mavic Pro for a week now, and everything is fine, except for one thing. I can't access the intelligent flight modes on the Mavic Pro. I followed all the instructions. I am in p-mode, the battery is over 50%, and I am higher than 3 meters from the ground! When I select active track, nothing happens. Then a warning says that I can't use the flight mode and I should try again later. Also, I can't use all 12-flight modes! When I select a flight mode, the same thing happens and the warning shows on the display. By the way, I am with the latest firmware. Is the problem from the phone? I am using Samsung A3, which is not recommended. Are any things which have to be turned on, in order to access the flight modes? Please HELP!
I would suggest you don't put the same question in two different discussions.
Find my reply in the other one.
Reactions: charliesRig
swordfish3860
