City Skyline Night Shot Settings
A1CMavic
New to the Mavic community; I’m heading to Chicago in a couple of weeks and wanted to get some night footage of the Chicago skyline/ Lake Shore Drive. As a novice with the Mavic Pro, I was wondering if any experienced pilots have gotten some good skyline shots, and if so what settings did you use and/or recommend?
Thanks in advance!
Depends on the light level. If these will be night shots you will need to do Long Exposure shots to capture all of the avaialbe light. If they will be sunset shots then by all means do an AEB capture with 3 or 5 frames captured and then combine them with a program like Aurora
It’s going to be a late at night shot around 11pm. Ideally, I’d like to pan across the skyline, and get some shots of the expressway. Any recommendations for the iso, sharpness, smoothing, etc?
You want the front LEDs off when you're shooting. You can turn them off manually in DJI GO 4 (there's a setting for on/off and you can assign that to a controller button).
There's also a setting called "Front LEDs Auto Turn Off" in the Camera Settings menu, which will turn the LEDs off for recording / shots.
Also, if it's a Mavic 2, there's a shooting mode called Hyperlight that's made for this exact scenario (I haven't used this mode yet, but I've seen examples, and it's pretty cool -- though doesn't produce DNGs).
Chris
Thanks in advance!
My night time settings are 4K 24fps 1/25 ISO 800 D-cinelike -2 sharpeness -1 contrast +1 saturation
Reactions: hactick
KiKiHUN
