Hi,
So i've got 3pc @Skyreat ND filters for my Mavic 2 Pro. The fit and finish of these filters is very good. They came in a plastic case and microfiber cloth.
For the install i just need to grasp the camera barrel, rotate the stock Filter, remove it and apply the @Skyreat ND Filter. Beware that the gimbal is a very fragile part so make sure you dont apply to much stress on it.
The filters fit on as good as the stock DJI Filter, a tiny bit larger, and are easy to install and remove. This filters do not interfere with the startup gimbal calibration.
They weight is about the same as the stock DJI Filter, i dont have a proper scale to post the results.
Bare in mind that the Gimbal Guard cant be used with Skyreat NDs applied, if you want to use it you must install the stock DJI Filter.
After my flight tests, i can say that there is no image distortion or color variation using @Skyreat filters. Keep in mind that i am not a Pro, so you may see it otherwise.
This is my first @Skyreat product but is showing good quality and very good aftermarket product/alternative, i recommend them very strongly.
Sorry for my not perfect English but that is not my main language, hope this can help you buy some NDs to your M2P.
![0xycWt5.jpg](https://i.imgur.com/0xycWt5.jpg)
