Drowned
barrancos
Hello,
Today after 1 month flying I drowned my mavic. Flying under a quite tall bridge, when exiting according to the app i pushed to go down instead of up. My fault. I still have in my memory that i was pushing to go up, but according to the app i am wrong.
Before paying for a new mavic, could some kind soul double check ? Here is the csv :
Dropbox - 2017-06-17_10-23-35_Standard.csv
Airdata UAV - Flight Data Analysis for Drones
Thanks in advance
Jordi
Were you able to retrieve the Mavic? If so, hopefully you had DJI Refresh
Hello,
Thanks in advance
Jordi
i Think something we all have done at some point luckily for most of us it did not end badly (Although i did the same over a waterfall but yawed the wrong way and thought my Mavic was a duck) luckily it gave the tree a haircut whizzed out and was all good.
Sorry to hear you lost yours this way.
Reactions: barrancos
Your flight log shows you had the throttle in the full down position at the end of the flight log.
Thanks msinger. Can you see there if sensors were on ? I always have them on , but just updated, and the mavic did not try to avoid the water.
Your log does not show whether or not VPS was enabled. Even if it was, the downward sensors do not avoid obstacles.
The sensors on the Mavic get confused by water they will not recognise it as water to the Mavic it is land and as such would attempt to land on it.
There are a lot of threads on flying over water and what to disable but as msinger says you were full throttle down so sensors on or off still means becoming a submarine.
CMDR DV TEARDROP
