Hi from Manchester, U.K
iainalexsmith
U.K
I’m looking into using drones for monitoring invasive species and the effectiveness of the treatment program we run at our company.
I only really have limited knowledge on drone use, mostly for leisure and have run a few missions on Litchi but could really use some help or mentoring if anyone has any experience.
I only have a DJI magic mini and was hoping to build up a competent level of proficiency before investing in a phantom.
Welcome to the forum!
You little Drone might seem like "Magic" but I'm assuming it's a Mini...
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Since you live in the UK be sure you are following all of the laws and rules applicable to you. You might find the flowing link of interest to you…
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mavic Mini. You will also find the 49-page Mavic Mini's User Manual, in case your Drone did not come with one.
Happy and Safe Droning…
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Hello from Minnesota USA and welcome to the Forum....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart and keep the drone in sight.
Welcome to the forum from the beautiful Rocky Mountains of Colorado! Happy and safe flying!
Reactions: Skywatcher2001
Welcome to the forum! :)
podrezoffc
