I have M2P and M2Z with very old firmware - RID module or activate latest?
pchaps
USA
My Mavic 2's have old firmware (perhaps 2020 year). I do some Part 107 work but also recreational. Getting back into it after some health setbacks.
It seems obvious to me to update firmware for RID inside the Mavic 2 -- but is there any advantage to keeping the oldest viable firmware and just adding a RID module? The expense of a module is not an issue.
Reactions: Cafguy
If you are just the normal Drone pilot I would update the firmware You can get a module I suppose BUT If you are not using any "Hacks" then why spend the money, Just upgrade.
Agreed get the update and if anything goes wrong, like the software hangs and the drone is bricked, maybe you can send it in and get another newer one.
Reactions: pchaps
Thanks that seems easiest. What are "hacks" for DJI?
Thanks I updated my DJI Assistant 2 and did the firmware update for the M2 Zoom, and it was very picky about the USB-C cable as I did not get the original with the used drone. Only my latest Apple USB-C to C cable worked!
Lesson learned: Why my Mavic 2 firmware update keeps failing? -- the cable! Must be a high-quality data cable like OG Apple USB-C to USB-C! Worked now!
Jiddles
