marco polo tag location
wytnyt
Va.
wheres the best place to mount a marco polo tag where it wont interfere with things?
ive seen them put on the side of the ac but that requires removing them to fold the legs
i mounted my tags on the right front legs of my mavics which allows it to be folded up
is this an issue?
marco polo only sends out a 50 millisecond ping when pinged,otherwise its dormant,least from what i read
are you familiar with the marco polo?
Sure mate, great looking bit of kit. My point is putting a piece of electronic equipment, and a transmitter to boot, (transmitting or not), onto an antenna of another device IS going to change the Q of that antenna.
But as I said, its your aircraft do as you wish.
i see your point,,where would you suggest putting it
mine has been here for a year now, no issues, I just just it on there
24/7 I can charge in that area , and fold it up with it left on. and its just velcro.
Reactions: Inspirephil
is this an issue?
I have the Marco Polo and i have it on the right rear leg. The signal that is put out is a 900mh i hear and the only time it is running
is when you turn on the receiver to fine it and it has already hit the ground then. Here is i picture. It
will fit in your case just like before and can be charged in the same spot. DSCN0257.JPG
for some reason, i'm getting blank posts. I'll try again sorry
Mounting The Marco Polo Tracker
Here is my attempt. Works. Flies without hindrance.
Here's how I do mine (good for swapping between multiple drones and for charging away from the drone if needed). Not sure why mounting it in the vertical position (putting the antenna closer to the props) would be better than my option, but TEHO.
Marco polo
Here's the mounting option I came up with for the Ultralight model:
odofi
