Mavic air 2 switch to FCC mode using an android app
Ah yes, sorry just saw it....thanks
Iit is also working on mini 3?
That I don't know. The generous guy that created it made it for the Mavic 2. I tried it on my former mini 2 SE and it worked just fine.
Just try it out, it won't cause any problems even if it doesn't work. If you roll up this thread, you will find a post where I explain how I made it to work.
its not working....but thanks for the link and for the sharing...
Reactions: Rui S
I have problems getting the FCC app to work on my Pixel 9 Pro. When i plug the cable into the phone it seems to recognize the controller for a second, but the popup dissapears quickly and I am not able to patch the controller. Didnt work when i was running Android 14 and doesnt work on Android 15 now either. I have no problems using it on my old Pixel 5 also running Android 14. Anyone having simular problems that might have found a solution for this? :)
Yes, everyone is having similar problems. It seems that Android 14 and 15 had deep changes on its OS and hacks are not working on those anymore. Even paid hacks are struggling with that issue.
So, use it enjoy it on your Pixel 9 Pro so long it doesn't update either. Nothing lasts forever...
Hi everyone,
I recently got a DJI Mini 4K and had a few hours free this weekend so I've updated the original app from @galbb to support latest android versions (8 to 15) and gave the app a better looking UI.
The code behind the scenes is the same as the original app, so if the old app worked for you, the new one should as well.
I've tested it on my Mini 4K and it works, I'd love some feedback from you guys if it works for you or not and what I could improve/change.
You can download it from the GitHub here : GitHub - M4TH1EU/DJI-FCC-HACK: A simple Android app that forces DJI NR1 remotes to FCC, all the code is open-source.
All the instructions and details can be found on the link above.
Hello All,
I have created an android app which allows switching from CE to FCC mode .
APK is attached , usage (currently need to use bottom type C port for patch only):
1.connect mavic air 2 controller bottom type C cable to your android device , turn on the controller .
2.run my application and press the patch button .
3.change your phone usb connection to normal top one.
4.then open DJI fly app normally and you can obsereve the change in the transmission tab .
Link to the apk
Hey can you please reactivate the dokument or at least for me please Thank tou very much
Hello All,
Link to the apk
Can you renew the fike please or at least for me thank you so much.
Hello All,
Link to the apk
I dont know if these send ir not but can you pleasw renew the package or at least for just me thanks a lot
There is app posted as an attachment in one of the answers. Just search and read, you don't have to ask the same question over and over again.
BUt it iw old or at leqst i cant open it or thw file is deleted
I downloaded app yesterday, so it works. It took me about 2 minutes to find it.
And yes, it still works. Even on Android 14. And still it is possible to have permanent FCC :)
Can you put s link because i csnt open the drive file
Hello All,
Link to the apk
Hello please make the document available again
Hi everyone,
I just want to say that I successfully got this working on my DJI Mini 4k on a Xiaomi Redmi Note 10S (Running MIUI Global 14.0.11 / Android 13) with zero effort!
Increased range by about 70% - First time I hit 1000m :)
Thanks a tonne!
Reactions: matt2525
Do you mean the hack is permanent even after switching everything off?
Roland
flydeep
