- Joined
- Oct 12, 2016
- Messages
- 29,144
- Reactions
- 32,438
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
New firmware has been released for the Mavic Air. The release notes state nothing other than the battery level algorithm has been optimized.
Been down that road before myself!I will wait a few weeks.
Yes it would be niceIt would be nice if DJI explained what "optimized battery level algorithm" meant in the release notes. I guess it's a good sign that they didn't note it's an important update (like they sometimes do).
The sensors don't work as well (if at all) in poor lighting conditions. When flying at night, you need to give yourself some extra room (just in case things don't go as planned).The A/C took off and was all over the place, did not hover in place, it was wild, crashed into the side of my house and now have four very scratched up props.
I doubt it has anything to do with a firmware update. Try flying during the day and see if you're able to reproduce that issue. If not, then it probably occurred due to poor lightning conditions.I have read pas updates have done this before, is this correct?
I did the update for one reason and one reason only..... I am interested in any changes in the way the AC worked before the update. I flew inside a dwelling as well as outside. Inside temp. Is 68 degrees F.
Outside is 31 degrees F. Both Daytime flying. Both indoors and outside flying are no different as before the update.
No changes in performance at all.
It has never grounded me. It will continue to nag you though until you update it.if you never update it wont it ground the drone at some point?
