Mavic Air wobbly footage unstable?
jphines45
Arizona
Need help?
I am not sure why my mavic air is doing this. I just recently did a full update calibration, IMU calibration, gimbal calibration.
This past weekend when I launched the Drone I noticed this wobbly and shaking kind of recording happening I am not sure what that is. You can follow this link and watch a little bit of the footage. Recording in 4k at 30 frames a second and the card speed was fast enough for this. I'm also using the Master Airscrew v2 props that are adjusted to what they recommend? Any suggestions
View Drone footage
check that the gimbal is attached correctly does look like jello due to prop shake when you say adjusted for the MAS props do you mean the gain adjustment maybe you went to far or the wrong way
sohil
