Do you have aftermarket / third party motor covers? if so and they are rattling then they may be loose. if your MM (Mavic mini) is stock and you hear a rattle I would verify all props, motor screws are tight. always use locktite as well. never a bad idea to use the screw driver that came with your MM as part of your Pre-Flight check to verify any and all screws on your MM are tight.Is it normal for the motor cover to rattle when the mini is started
Is there anything around the house that I could use instead of the Loctite because I don’t have none at the moment with anything else substitute LoctiteDo you have aftermarket / third party motor covers? if so and they are rattling then they may be loose. if your MM (Mavic mini) is stock and you hear a rattle I would verify all props, motor screws are tight. always use locktite as well. never a bad idea to use the screw driver that came with your MM as part of your Pre-Flight check to verify any and all screws on your MM are tight.
Do you think it will cause any harm from them rattlingYes if you have the Aluminum Motor Covers they our very loose.
The Neoprene ones we use work with a 3m adhesive to stay tight and keep the props on tighter.
Phantomrain.org
Gear to fly in the Rain
Coal
Yes it is I was thinking about buying low noise props but here is a picture of the motor View attachment 94414
Yes I do lol. I will most definitely try ur technique.thank uSo not a fan of loctite on these screws as they our easily stipped , so careful with that.
So what you could do is do you still have the package these came in, you will notice the package is made out of foam. If you have some scissors you cut a small strip of that foam core and than cut it again so its thinner, like 1/16 and use that under the prop covers, should snug it up .
When your ready suggest you get the mavic Wet Suit so as to avoid all future problems.
The Neoprene Covers our the best because they provide benefits both for protecting and tightening.
This is the quick hack I came up with but you might not have the package material .
Phantomrain.org
Gear to fly Mavic Mini in the Rain.
I'm not sure I'd trust covers that have the prop screws go through the covers to bolt to the motors. In that configuration, you would have to use non-stock screws. You can't be certain prop tolerance for up/down movement is to DJI specs.
Now those covers that bolt to the motor and props that bolt to the covers with stock screws have a better chance of maintaining stock tolerance.
I have this kind.I'm not sure I'd trust covers that have the prop screws go through the covers to bolt to the motors. In that configuration, you would have to use non-stock screws. You can't be certain prop tolerance for up/down movement is to DJI specs.
It has been tested by many and found the covers do not affect motor temperature.I would not use them.
They will just burn up your motors.
They are open for a reason - cooling.
But would the propellers be able to move freely with it being bolted down like thatI wouldn’t use the floating covers, these screw into the motor body, don’t use the sunnylife covers they are garbage with terrible tolerancesView attachment 94458View attachment 94459
