Hi guys,
Should get my M2P (with Smart Controller) early next week.
Do you fly it as is or is updates very important?
Thanks
Thanks
you "can" fly it as is but I WOULD download the DJI Assistant and update it
Hi guys,
Thanks
Hi guys,
Thanks
While not required, I like to run the latest available updates. Being in software development for many years, I know that many resolved bugs are often not mentioned if nobody outside of the engineering team has discovered them. And if the engineers took time to make improvements, there was likely a good reason for it.Do you fly it as is or is updates very important?
DJI doesn't require people to run the current firmware. However, they might recommend updating the firmware as a troubleshooting step if you contact them for help.additionally you can often find yourself receiving less than normal support if you are not on the latest release
You can install the firmware from DJI GO or the DJI Assistant 2 application. Internet access is required no matter which you choose.You don't actually need DJI Assistant 2 to upgrade, do you------provided you have internet access-------and assuming you have Go4 running which I believe would be the case for the Smart Controller anyway?
I would download the DJI Assistant and update whenever required. You can do it without the DJI Assistant but I have found that easier than just relying on WiFi.Hi guys,
Thanks
Not upgrading firmware is a lack of Proper maintenance of Aircraft, according to PT107?
I didn't want to presume, but the logic still stands updates are updates for a reason
