Edit 7-29 - When I bought the Air2S I was dissapointed in it's reduced flight time compared to my old MavAir2. Now I have way more power than the MavAir2. The power increase is almost up to an EVO2's Flight duration or maybe the same. Gives me more time to loiter around and look for better video and photo compositions. - END EDIT.
Hello Everyone,
I observed a Battery Mod Test Flight of the Air2S today. The battery, shown in attached photo, is a TATTU 1800mah 75C 11.1v 3S Lipo w XT60 power adapter. The Mod Adapter is made by STARTRC, just look at the attached pic. It has 2 XT60 connectors to attach up to 2 batteries. This test wasn't a usual time and record test. It was a realworld test comparing the pilots normal flights with no batt mod attached and with batt mod attached. The results?
With no batt mod, The pilot went straight to his usual destination where he only had 5% battery upon his return home landing.
With the 1800 mah battery mod, on the same day, same flight his battery level was 25% upon his return home landing.
This increase gives the pilot more time to loiter during the flight and take shots he may othewise have missed. I'll have to let you all know, if he buys another battery and tests two at once. But he says, he worries about the stress on the drone the added weight may cause.
The test was repeated twice. With the same results. So if you're an Air2S pilot and want to have an extra 20% power added, then by all means get the mod. It's super cheap. The flat cable mod with 2 battery attachments is about 7-10 dollars USA. The 1 Battery is only about 30 dollars USA. This extra 20% battery life only gives the pilot an added 5 minutes max, to the flight. It's cheap, it's doable, it's easy. It's just up to you.
Hello Everyone,
