Nah ... that cell deviation was way to small to have caused this ... the cells behaved until the bitter end & the log don't show a sudden death of a cell.I flew to capture a ferry passing at breaker bay
then sudden disconnection from RC & no RTH - was allgood then gone
Now I have no drone
Can someone analyze my flight & tell me what happened
Looks to be outside any restricted zone, so what would be the issue?Can I ask why you lauched 2km from Wellington airport runway?
From New Zealand Airspace Maps for Drone Pilots | AirShare NZ hub for drones and UAVs
That looks to be much too close to a large airport.Looks to be outside any restricted zone, so what would be the issue?
Look againLooks to be outside any restricted zone, so what would be the issue?
Blue Zone was unlocked - nowhere near a red zoneLook again
Wondering where you can and can't fly your drone in New Zealand? Low Flying Zones UAVs are not permitted to fly in any Low Flying Zones, which are coloured orange. Military Operating Areas Permission from the administering authority is requested to fly in the green zones.www.airshare.co.nz
If I had intercepted a no fly zone I woulda got a vocal warning & drone stop flying forward / into zone & hover at edge of it as it usually does - would still have had controlThat looks to be much too close to a large airport.
It doesn't explain the loss of signal but the error message earlier in the flight should be considered if looking for no RTH explanation.
Current RTH route will pass a no-fly zone. Pay attention to the aircraft's position to avoid RTH failure.
It might or might not be the explanation.
It is like the battery ejected, aye... but I am sure it was secure - it was a Mavic 2 pro - warns if battery not secureNah ... that cell deviation was way to small to have caused this ... the cells behaved until the bitter end & the log don't show a sudden death of a cell.
This flight was pretty straight forward, besides that you started it with only 62% battery ... perhaps earlier flights just before?
You quickly ascended up to 67m height & then pinned both aileron & elevator stick making you flying in a 45 degree angle compared to the yaw direction ... just in the end you fed in some rudder also.
Below show the red flight path together with the AC position when the log ends ... green bar = yaw direction & yellow tilt direction.
The battery info from the log doesn't show anything abnormal ... the log just ends at 67m height with a battery on 60% going with a heading speed just above 14m/s ... then nothing.
So ... nothing in the .TXT log give a reason for this, all very typical to either a electrical fault or a ejected battery that cuts the power making the motors stop & the RC connection being terminated.
Maybe some more can be discovered from the mobile device .DAT log ending with FLY063. Read up here how to retrieve --> Mavic Flight Log Retrieval and Analysis Guide (read under section 3.) Attach it then in a new post here.
been looking, can't find itEven though the restricted zone in the area could come into play in this case ... I doubt it due to a couple reasons.
First looking at the disconnect ... this was a Mavic 2, which haven't been prone to strangely & suddenly loose the connection as other AC like the MA2 & Mini2 . This at only 191m distance & totally without any signal disturbance at all before the log ends.
If then looking into the possible flight restrictions there out from the DJI FLY Safe ... which is what could prohibit a take off or induce a auto landing ...
Already at 4.4sec the HP is recorded, so it isn't like the AC is well on it's way when the position becomes apparent due to a lack of position fix at take off & the DJI FLY Safe kicks in. Instead this flight must have been authorized through the GO4 app as it's a blue zone which gives that possibility.
Still think's that a power loss in the most likely conclusion ... but as the log doesn't reveal the cause everything that remains is guesswork unfortunately.
@RokkoRokko ... have you tried to retrieve the mobile device DAT log yet?
I have flown hundreds of flights - this the first issue like this - I will still be confident flyingWhatever it happened to your drone, how much confident will you feel with your next drone flight in the future?
didn't think this was issue, just something I consideredThe CSC stick position will not stop the motors in mid air unless the drone thinks it has encountered an emergency or you changed the respones from "breakdown" to "Always" .
