System cant process 4K with info from MA
John Gowland
Perth
My new Macbook Pro which I particularly bought for processing 4K video from the Mavic Pro cant process Mavic Air with info on it. It can process 4K video without the info on it with out a problem but when I take video with the info on it the machine can't do it. Its all jumpy like the cpu or graphics card just cant cope.
I shut everything ells down, restarted then replayed it a number of times to make sure it was in all the caches.
Even tried Turbo Boost switcher.
Any one else experienced this.
It looks as though the information in the video clip is way too much for my very expensive Mac.
Can anyone elaborate?
"somebody gonna get a hurt real bad"
Do you have a SD card with 100 mb/s support?
What do you mean by the video with info? Playing with the associated SRT file? I find my older (2014) Macbook Air plays 4k fine via QuickTime but VLC struggles and stutters. Quicktime however wont use the associated SRT file but VLC will.
Supposing you're playing with VLC if it loads the subtitle file, and yes it's known to not handle that smoothly. So move the SRT file away into another folder when using VLC to play the file. Or just play with Quicktime which won't load it (and be graphics accelerated unlike VLC).
You people are too smart for your own boots.
Formated the sd card in the Mavic Air. Thanks Kilrah. Worked fine when I removed the srt file in V/LC. Prior to that it worked fine in Quicktime.
slus
