USA Drone Flying.. Are you labelled up?
25th Feb 2019 new USA FAA rule about label location $27500.00 max fine if not displayed... do you think they'll make an example of someone?
No. FAA is not a police force and doesn't have the personnel. Where did you find the $27,500 number?
Reactions: Drone on
Local law enforsement have authority to check and then report to the FAA for consideration.
The amount comes from the failure to register the drone. If you don't abide by the rule as a whole, the drone is not registered. That is not saying that a person _will_ be fined that amount. It is just the highest amount of the fine.
Reactions: Mavic Pro Platinum
I have always had mine on the outside. I write it on the outside of the battery in White Scripto
Mine is in the battery compartment and underside, between the sensors.
On my P3, I have it on the back near the battery compartment, and on the bottom near the ultrasonic sensors.
Here's a photo of the FAA regis. number on the rear leg of my Mavic Pro. I also have three-blade propellers (love em!), leg extenders (protect gimble on landing), and a bright 3-strobe mini-card mounted at the front of the bottom plate. Video of strobes
Reactions: bbooty
I purchased a nice set that came with a nice FAA reg card. I would've used my dymo, but I don't have clear labels for it.
dojin23
