Virtual Litchi Mission
only pc - sad. perhaps we should take up a collection and get him a mac to develop on... this tool is great....
timmy
Reactions: Neebles
In this thread started almost a year ago - https://mavicpilots.com/threads/how-hard-would-it-be-to-simulate-litchi-missions-in-google-earth.7864, user “torqum” introduced the intriguing idea ‘flying’ a Litchi mission virtually in Google Earth to see how it looks from the perspective specified in Litchi. It was a very appealing concept – to fly a mission anywhere in the world without getting out of your armchair!
In that thread, user "JTS" submitted a conversion program which apparently worked for some folks but not for others – and not for me so I decided to write my own.
The utility is called Virtual Litchi Mission (VLM) – it is a standalone executable and does not need any installation. It runs on my Win10 x64 machine but should run on x86 machines as well. On older versions of windows your mileage may vary…..
VLM sets a watch on a user specified Downloads folder and will automatically read any csv file created in this folder. When Litchi Mission Hub writes a csv file to this folder, VLM will convert it to a “Tour” in Google Earth including the complete camera orientation and gimbal settings which were specified in Litchi.
The resulting Virtual Mission can then be flown in Google Earth and should show results very similar to that obtained when the mission is flown with your drone. I have tried it out on quite a few of the public missions available in Litchi Mission Hub and in areas where the satellite imagery is good, the results are impressive. Google Earth is so amazing!!
I have found VLM useful to check that there are no erroneous parameters in my Litchi Mission and to check that the camera ‘sees’ what I want it to see. It has saved me several wasted flights with my mavic.
A full User Guide is available in VLM under the Help Tab
Please give VLM a try and let me have any feedback, comments etc. I hope you find it useful.
Thanks
Hi,
Is there a VLM for IOS MAC ?
Thanks
This is great...might suggest updating the file on the very first post with the latest version as you go. Great tool!
Now if I could just get the heights of the trees updated in Google Earth! hahahahha
Reactions: Rnl
Thanks. I've tried updating my first post several times in the past but the web page always crashes when I click "other options" - anybody know how to update an attached file?
Use boot camp or Parrallels on the Mac to create a virtual PC and then you can run VLM on a Mac
Reactions: Brojon
I hope somebody can help me, I can get everything working all the way up until I get to google earth, it wont show up in goggle earth. It says it was sent to google earth but I cant see it.
anybody ever have this problem?
Thanks for any help
Thanks for any help
In your Temporary Places in Google Earth you should see a folder with the name of your mission. Inside that folder are two sub-folders - one is called "Virtual Mission" and the other called "Diagnostics". Double click on "Virtual Mission" and your Mission should start.
Good Luck
N
Thanks, I got it working, I had to change the name of the file and now it works.
When Litchi released the upgrade to their Mission Hub recently (V1.1.9), they upgraded the csv export file format to include speed and elevation reference data and this forced me to sit down and make some corresponding updates to VLM.
Here is the result - Virtual Litchi Mission V2.0.0. Please give it a try and let me know how you get on….
There are quite a few significant differences from the previous version :
1) Version 2.0.0 now incorporates a built-in Chrome browser to access the Litchi Mission Hub. This allows better integration between the Mission Hub and VLM and will hopefully allow for direct integration with Google Earth Web in the future. Unfortunately this makes the download considerably larger than VLM V1. It also means that VLM V2 requires installation and is no longer a standalone executable.
2) There is now a “Profiles Panel” which can optionally be shown below the Mission Hub Panel on which you can plot drone altitude and ground elevation. You can also plot heading and gimbal tilt angles if required.
3) As mentioned above, Litchi introduced some changes to the csv file output by the Mission Hub in their new version 1.1.9. This extended csv file now includes speed and ground reference information on a waypoint by waypoint basis and this new information is now handled properly by VLM V2. It is now very easy to create a mission with elevations relative to ground - provided you trust Google's elevation data!!
4) Prerequisites for installation of VLM V2 are Windows 7/8/10, x64/86. There is also a requirement for .NET4.6 and VC++ 2013 Redist but these should be handled by the installer.
5) Unfortunately the installer is about 56MB and so too big to upload to MavicPilots directly. You can download the installer from Dropbox here :
Dropbox - Virtual Litchi Mission V2.0.0.zip
Please let me know how you get on.
N
Reactions: Hauptmann
namirda, this is amazing. I really appreciate the effort you've put into this and hopefully continue to do so!
Really... this app and even the earlier version(s) have save me a great deal of time in planning out missions.
Before, I'd set up a mission, check and double check it and when I flew it there were tons of things I didn't consider or think through enough.
In most cases it was a failed trip and hours of my time only to have subpar video.
Now, I can set up a mission and fly it and (admittedly) I may have to make 20+ tweaks before it's "golden" but the end result is so much better and a more efficient use of time spent in the field.
Thanks again for your work and I hope you stay encouraged and continue to upgrade an already great product!
namirda,
I'm trying the new version for the first time and I might have discovered a bug (unintended feature).
If I load a mission for the first time, the profile plots look as expected.
If I load another mission the profile plots don't change *until* I export the csv from mission hub (to GE), then they change to match the new mission I just loaded.
Hope that makes sense.
mariovaleo
